Has anyone used the groundhog max disc plow with their Mule? I just bought a '20 pro fx and was thinking about buying this disc for some hard to reach food plots. My biggest concern would be bending the hitch receiver.
You're not going to bend that hitch receiver with that plow.
Just make sure the ground is somewhat moist when you plow.
No heavier than it is you’ll be fine. I would drive my Tracker back tires on some wood 4x4 blocks and drop the groundhog as low as I could. Shove it into 4 low and the tires were barely brushing the ground. A few times doing that and I pulled the 2 front hitch bolts through the frame. Threaded inserts and bolts too. ? Live and learn!
