Handle Bars and Grips ?
1 reading
2K views 5 replies 6 participants last post by  chopermech
#1 ·
I'm using Easton EXP handlebars and if I keep the shifter on the handlebars I only have about 4" of bar for the grip on the left side. If I use ODI Rogue Lock On grips will this be enough bar for the grip. I'm guessing the grip will end up sticking out abut 2" past the end of the handlebar. Is this ok ? Thanks.
#2 ·
No, both lock rings for the ODI's have to be clamped to the bar. Only using one will let the grip pop out and fall off.
#3 ·
RPM is correct.
