Head removal
1 reading
12K views 19 replies 8 participants last post by  ibuadoariel
#1 ·
Can anyone tell me if I can remove thge heads and jugs in frame on a 2003 650 prairie?
#2 ·
Yes, you can. But that front cylinder is really fun. The steering stem is right in the way for many of the steps.:frown2:
#4 ·
You sure can.
#9 ·
Yes, it will, as long as it's a solid rear axle machine.
#10 ·
Wow, that sucks. Looks like the valve let loose. For the front head, just remove the front lower motor mount bolt, and lower the front of the engine. Then you will be able to remove the front right rocker cover bolt. I usually just take out the front and rear engine motor mount bolts - makes it easier to remove covers and heads.
#12 ·
Search the net for a free PDF 2003 Prairie 650. Should find at least one or two.
#14 ·
manualslib.com has all of the SRA service manuals for free. I have a Bayou 220, P650, P360, and BF SRA in the stable, and was able to find manuals for all on that site.
And I realize that the P650 and BF SRA are the same machine, but I have both so I can take separate notes in the manual as I work on each of the machines. :)
#15 ·
Hey, where's those engine porn pics ? LOL
#16 ·
Did you find 1? If not message me an email address.
