2011 brute went under water cute its self off got it out flushed everything out all the oil is clear and diffs are clean also but i have a several shortage of power belt is dry and fine i dont know what else to do :(:(:confused:
Be more spacific?? shortage of power?? what have you all done? etc..
i have drained oil like 8 times its clear now changed the front a rear diff new air filter when i get on the gas its a lot of normal engine noise like normal put dosent have the torque like it did before
If you are reading this message then all you have to do is hit the back button and you'll see a screen like the picture below. Then just click on the button that the red arrow is pointing at (the arrow won't be there on your screen). Fill in your questions and then press the submit new thread button.
