1 - 9 of 9 Posts
do they make a high flow fan for the brute that goes in place of the stock fan I know highlifter makes a triple flow rad. with a good fan but there is nothing wrong with my rad. I just want a better fan. gotta 08 brute force 750
they sell a 10" fan at advanced auto that works a lot better than the stock one
auto fan did not hold up long, after some mud and water, then powerwashing..
Spal makes a nice fan about the same size as stock but with more blades so it pulls more air. I bought one on e-bay the guy includes a bracket that lines up with the stock holes, all you have to do is spice your old stock connector on from the old fan. It has held up now for a few months with no problems. His price was not much more then the fan it self.
have you actually used and auto fan? or are you assuming that it wont last long?
I have actually used the auto fan, it lasted about a month(4-5 rides maybe 100 miles), I power wash almost after every ride and I ride some water and mud. I think it is the washing. It stopped working then popped the fuse, when I pulled it out it was seized up. My stock only went when the fan bushing(mount) stripped.
The new fan from spal has lasted a few hundred miles already and has been washed the same way.
ok thats good to know i was going to buy an autolite one soon but i guess i need to look for different ones lol
i was considering a better fan. that ebay seller had one for a p700/bf650, would that fit the p650 or is the fan mount different?
Vendor
I have the Muzzy fans 40.00. It replaces the stock fan blade with a metal one from a refridgeration unit fan (larger 4 blade with more pitch). I have it on my Teryx. when the fan does come on, it only runs for probably 10-30 seconds.
cheap alternative.
1 - 9 of 9 Posts
