Hot Prairie
2448 Views 8 Replies 7 Participants Last post by  Camo Joe
I have a 2005 Prairie 700 thats constantly overheating and "puking " ouy coolant. Has anyone else had this problem, does anyone know of an aftermarket radiator that will help cool this beast?
1 - 9 of 9 Posts
radiator is not the problem
It may be plugged up/caked with dirt/mud, check it closely
does your fan come on?
Radiator is clean and the fan does come on. The dealer told me when I bought it that they have a tendency to get hot especially sitting still because of it being a V-twin and because of all of the plastic that surrounds the motor.
that's bs...they don't get hot enough to puke coolant unless something is wrong
use a flashlight to peer through the radiator....they can appear to be clean but can be clogged down in the fins. Sorry if you've already done that.
May want to check radiator cap also
mine puked out coolant, hotter than a two dollar pistol! fan came on everything thermostate opened up at the proper temp everthing appeared to work as it should could not fix it so I sold it. The guy took it to a great mech. it ended up being some sensor in the cooling system that was bad a $12.00 part...I still kick myself for selling it... Find a great mech. and spend the money, sometimes its worth it.
go spend $100 on a non contact thermometer that you can get true temps with (you can point it at the area and it will give the actual temp you should be able to see the temp go up and down as the thermostat opens and closes and the temp at the fan switch) and check the thermostat housing it should open at around 160 if it doesn't replace the thermostat the shop manual doesn't say what temp the fan should come on at, but I would imagine 180 or so there is also a coolant filter that could be a problem but i doubt it mine was getting hot and it was a dirty radiator, a little careful pressure washing and its all good now and i ride summer time around 98 degrees not overheating. check and clean everything process of elimination start with the cheapest part, also look in the radiator cap while its running to see water flow pump could be bad but not likely. good luck.
Be sure to check the circuit breaker for the fan. Mine would quit once in a while with no warning. Replaced it with an inline fuse. no more problems.
You might want to consider an aftermarket water pump from Fundy.. People are having real good results from them.. I should have mine in a couple days. I'll let ya know how good it works...They are 100 bucks..
Where is the coolant coming from?
Is there enough coolant in the mix?
Is the cap on correctly?.......is it good ( the cap seal)?
Is the water pump pumping?
You may have a blown head gasket...................pressuring the system..........
1 - 9 of 9 Posts
