1 - 8 of 8 Posts
I want to set up hot start reverse lever on my kfx400 but I don't know what cable to use for it. Do you use stock reverse cable or is there a specific cable to use?
Use the reverse setup off a kfx450 and you can use the same cable.
oh yeah I guess that makes sense. thanks. Ok another question. Do you put the lever before the light and choke piece? If I put it after like the stock one I think it would be too far to hit the lever
The kfx450 setup is on the throttle side. It is setup almost exactly like the D.R.D. setup.
Discussion Starter · #6 ·
Thanks for the thread jonboy. It explained everything. I was looking at new clutch levers and seen one with hot start I figured I could just get that instead of buying the Dr. D kit, but this is a whole lot better. Thanks again.
No problem, Just post pics of it for others to see when you get it done.
Discussion Starter · #8 ·
One more thing before I order the parts. Do I use the stock 400 reverse cable or the stock 450 reverse cable?
1 - 8 of 8 Posts
