It's just a fact that a belt that curls too tightly around the primary spindle has enough contact surface to grab enough to squeal. That is always the case with anything under 22mm and sometimes even deflections at 22mm..(which is the minimum BTW) because when everything is heated, that deflection reduces to 21 and less. If your deflection is 23mm cold and the spindle is smooth...and the bottom of the belt has no shiny spots, it will not squeal..hot or cold. However..if you just sit there, stopped in gear running and let it ride on that belt long enough to make a shiny spot, it will squeal there. So, rule of thumb- target deflection should be 23-24mm and never just sit there in gear while shooting the sh*t. At least put it in neutral so it can rotate a little.
CV-Tech put a bearing there so they don't have to worry about theirs. I wonder when Kawasaki will take the hint.
