1 - 12 of 12 Posts
I have an 07 kfx 700 that will start right up with the choke on, but will not idle when the choke is off. Is there any suggestions on what i need to look at? Thanks for any help.
Have you tried adjusting the idle speed higher?
raise the idle up
idle
I tried adjusting the idle using the adjustment screw. I noticed that when i covered the air intake hose with my hand it evened out and idled fine. Anyone tell me whether my sensor is bad?
when was the last time you adjusted your valves?
There is no sensor.
Discussion Starter #7
never
I bought it about two months ago. I have never adjusted valves. Where can i find info? Is it pretty simple? I thought there was a mass air meter on there like a car.
It has carbs; therefore no flow sensor.
There's a million threads regarding adjusting valves; try the search function.
Sounds like if by removing air it idles ok. Then you may have plugged pilot jets. I would start there clean your carbs.
If it starts right up its unlikely its valves.
1 - 12 of 12 Posts
