Idle is slow to come down after WOT. No vac. leaks and carbs are clean as a whistle. I've got a theroy just want to see if anybody comes up with something I may have over looked. These are stock carbs with 1/8 drilled mains, needles shimed 4 #4 washers, 45 pilots. Running EHS lid, plugs have very little color.
I think that usually means its too lean (usually from an air leak somewhere). Do you have the MS mod?
I was thinking the opposite, too high.
Happened to me and it was the front choke cable was binding causing the choke to be slightly on all the time.
How can I get more fuel to it, I'm big as you get on jets now.
