Got a 2019 Pro-FX. Worked fine since purchase a year ago. Parked it after a day of use. Next morning inserted OEM key into ignition switch and it won't budge; as if I have wrong key. I tried wiggling key, pushing in harder, not pushing in completely, all to no avail. There is no evidence of wear on the key itself. Reminds me of a door lock that had same issue and upon disassembly one of the tumbler pins had moved. I was able to realign pins and reassemble lock.
My assumption is Kawasaki will honor 3 year warranty and authorize replacement of ignition switch. If not I’ll try to repair it before buying replacement part (~$72 at Partzilla). I was wondering if anyone else has experienced similar issue?
Discussion Starter #2
It was a tumbler pin. Kawasaki dealer straightened pin and all's well....for now.
Did the dealer disassemble the ignition lock? Or use a spray and free it up?
I would have thought they would just replace the lock under warranty.
So my guess is they tried a spray and it worked. Plan B would have been replace the lock?
I build, install, and repair locks at work. Buy a can of this, you can thank me later. We call it locksmith in a can. Whatever you do, don't use wd 40 in lock you want to keep functioning for years.
I do indeed need to thank you. Kawasaki fixed my ignition switch, but I also had a dead bolt lock on a door with the same problem. At your suggestion I bought a can of Houdini Lock Lube and with 1 squirt lock's as good as new.
Discussion Starter #6
The mechanic said he took the lock apart.
