take off the side cover of the motor then look in the bottom left coner.there will be a spring take the off then pull the shaft out like 1 inch then pull down the sliding piece connected to the shaft take that off then pull the shaft out put it back the same way you took it apart its simple you should be able to figure it out im 15 and did it
