Yes with the black foot guard thing has to be bent. Just bolt it on like normal and then pull it out till it isn't hitting the pipe anymore.
My pipe was also hitting the frame in a few spots you just gotta keep adjusting it all until the head pipes are not touching the frame.
Just a heads up the SP system does not get hot at all. There really is any reason to wrap it unless you just like the looks of wrapped head pipes.
I no longer have the SP system as I could never get it to stop leaking right where the pipes are held together with the springs
