The unit itself does not come with hot and negative wire pre-measured for the FXT. I had to use half of the negative to make it to the battery from the front. Then used the remaining length of ground to anchor it under the hood scoop. I removed the housing of the swith to install in the dash. Then pulled the Mule into my trailer as a test. Yes, I recommend but you'll have to modify the lines and remove the switch housing.
