Magnet, not quite following you. Is the battery discharging to 0 with the key in the off position or is the battery rendered useless (won't hold a charge and fails a stress test)?
Sorry, battery just won't keep up, I can only winch once or twice depending how much time in between, before battery is out of juice. just need more capacity for winching.Magnet, not quite following you. Is the battery discharging to 0 with the key in the off position or is the battery rendered useless (won't hold a charge and fails a stress test)?
The automotive battery sounds good. I should maybe have a switch to disconnect that battery from the system then and like you say charge it at end of day.The problem is the second battery idea will only work for a short time until that one is drained also .The charging system will not be able to keep up with two rapidly discharging batteries.The only other alternative would be to make room for a small automotive battery that would have alot more storage and then charge it up at the end of day because once again the stock system won't keep up.
