I bought a toy for the water and that went well..😃
So I bought a toy for the land but thats not going so well..😞
I’ll just explain.........
2 days ago I was checking fluids In my Kawasaki KFX 400 quad, and the oil was low barely reading on the dipstick...So I Filled it....after which the quad ran fine, UNTILL TODAY! when I was double checking my oil and DISASTER STRUCK!! 😫
When I opened the cap Oil started spouting out everywhere!.....LOTS OF IT!!😳
It wouldn’t stop so I recapped it! I also noticed that the oil coming out smelled of gasoline WHAT THE HECK DID I DO WRONG?? Can anyone please enlighten me? I’m thinking I overfilled it! 😠 BUT WHY DOES IT SMELL LIKE GAS😬😬😬
Hi , looks like you have a carb problem , fuel is getting past the needle valve either getting stuck thro wear or a minute piece of grit holding it open allowing fuel to run down the inlet tract into the motor if you do not shut the fuel off it will drain the tank . [ this happens a lot with lawn tractor B+S motors ] . simple fix [ subject to carb access ] is replace needle valve and or seat + fuel filter and switch fuel off when not using the machine .
