I just snorkeled my 04 prairie 360 and it isn't running right. It is idling okay, at part throttle it stumbles a little then it runs fine up to wide open throttle and starts to sputter.
I know I need to do some jetting but I'm not sure where to start. According to the plug it's running rich so I need to go down on the jets. This is verified by the fact that it gets worse when I try to choke it.
What jets come stock so I can get a few to start with? I can't read these so I don't know what size they are.
This indicates your snorkel is too restrictive.
If you didn't change anything in your motor and you put a snorkel on then have to cut fuel then you cut air. Now if you go smaller with jets your losing power by doing this
