u can't clean spark plugs no more replace only
secondly gas in the crankcase doesn't necessarily mean that the carb is bad. The fuel pump is a pulse operated pump, the pulse comes from the crankcase pulsing as the engine is running. If the diaphragm is leaking gas will get into the oil
lastly and frankly the most common cause of gas in crankcase is....normal. Yeah it's normal. For those that don't know all Mules other than the MX and FX/T's are all powered by industrial engines. Industrial engines were designed to start, then run at 3500 rpm (+/-) for hours on end, at full load. Well on a lot of these Mules, they start and idle and shut off then start and idle or go real low speeds, then shut off, restart, same thing. So what happens is.....the lube oil in the crankcase never gets hot. There is normally always going to be some combustion vapors that get into the oil, it is considered normal on any internal combustion piston engine gas diesel or whatever they are not perfectly sealed. Over a period of time which can vary, those vapors build up and the oil level rises, because it has fuel in it. Remember, almost all engines since 1980-ish have a closed crankcase ventilation system, in that on the Mules (most of them) the crankcase vent is plumbed to the carburetor or air intake in a way that any oil or vapors in the crankcase are burned. So on the 610/sx/etc when the oil level gets too high with fuel vapors it pukes the vapors directly into the crankcase vent, which goes to the air intake on these, where it's ingested by the engine and "burnt"....making the engine run RICH, resulting in FOULED SPARK PLUG(S), smoke sometimes, poor running etc.
The cure? If you use it that way (frequent start stops lots of idling and low speed operation), use low gear. It's just another gear in the transmission you won't hurt anything. If you're going to the mail box about 300 foot or so (or whatever), in low gear just throttle up and let it run on the governor once in a while. It's designed to run that way (industrial engine) you won't hurt it and frankly it's probably better for it---and I know, you're gonna say heck no I ain't racing my Mule, I don't want to wear it out. Fine. Deal with gassy crankcase.
