1 - 14 of 14 Posts
2005 Kawasaki Prairie 360 4x4
Hello guys, first time posting here and first time ATV owner so please bear with me. Just purchased this 2005 Kawasaki prairie 360 4x4. Its in very good condition and the only issue I've found is a loud nose when I put it in gear. Either reverse or forward. My guess is that it's the belt/clutch area but don't know what's causing it. It doesn't do it while I'm riding, only at idle. Any help will be greatly appreciated. I'm attaching a video of what's going on.
Sounds like belt whine. Belt may be way too tight.
Could also be a bearing. Need to pull clutch cover and inspect the belt. If it’s within spec, bearings would be next. Either the clutch bearings themselves or the bearings in the case where the primary and secondary come through.
It's that something that a rookie like could do or I need to have someone with experience look at it? Thanks for your response!
You can definitely pop that cover off the clutches and take a look at the belt. If it’s really tight or loose then it’s something to investigate further. Have to pull those 10mm bolts from the cover the loosen the Phillips screw from the cover exhaust boot. Just don’t turn on the ignition with the plugs unplugged or you’ll have to do a belt reset.
Belt is too tight.
Does it try to creep ahead when you put it in gear? If it doesn't, you can just run it as is. If it creeps or you don't like the noise, then the belt tension must be adjusted.
The belt is on the tight side, but that's about where I like them. The bike is snappy at that setting (not that Kawies aren't naturally snappy bikes).
If you don't like it, loosen it a tad, or just ride it a couple hours. It'll go away eventually.
  • Like
Reactions: Cgiese80
Discussion Starter #7
Belt is too tight.
Yes!!! Belt feels really tight and it does want to travel when i engage it in gear
Discussion Starter #8
It really is tight. It does feel snappy too. You nailed it. I bought it used and I'm pretty sure it won't go away by riding it anymore 😩
Discussion Starter #9
How do I loosen the belt a tad? Thanks!
Take the secondary clutch off and add a thin shim between the sheaves. You can buy a clutch compressor from EPI, or make your own. Get the shims from ebay, dealer, or oem part supplier. Or you can make your own.
  • Like
Reactions: Cgiese80
Discussion Starter #11
Ok, sounds good! Next step is to find out what shims and sheaver are 🤣. I bought the puller tool for the primary, do I need a different tool for the secondary as well?
You'll need some way to compress the clutch. A clutch compressor will work on both the primary and the secondary.
Or you can take it to a dealer.
If that's not possible, than download the service manual for it and follow the directions step by step.
  • Like
Reactions: Cgiese80
Discussion Starter #13
I'll do that, remove both clutches and take then to the dealer. It'll probably be cheaper that way uh? Should I just tell them to add a shim and check the primary? Someone mentioned that by looking at the video my shoes are shot. I got a new video BTW.
Clutch compressors are way cheaper than dealer hourly rates. If you've got tools and a little time, it's definitely cheaper to do this job yourself. Especially if you're going to be riding a lot.
But the shoes are a different story. The tool to change shoes is scarce. I don't even own one. One of the dealers near me doesn't even have one. You'll need to determine if the shoes are worn, then go from there.
You'll also need to trust the dealer you take it to. Crooked ones will say you need new shoes whether you do or not.
  • Like
Reactions: Cgiese80
1 - 14 of 14 Posts
