my kawasaki 360 4x4 won't do anything i mean i move the shifter to high nothing i move it to reverse nothing same with low. the shifter is moving but it won't engage and the neutral light stays on green.. it does have a weak battery but i pull started it and revved it up and still nothing.. need help.
Sounds like the linkage may have come unhooked somewhere. If you look up under the shifter side you should be able to get an idea of whats going on to start.
