1 - 11 of 11 Posts
Does anyone know what could cause this problem? Brand new 2019 ranch pro fxt with only 78 miles on it and it started jerking when taking of in high range. Is this clutch problems?
Does it do it with the drivers side seat belt connected? They have a speed limiter safety switch built in to the seat belt.
Yes, the seatbelt is connected. Noticed it getting worse as the ride went along. It only does it when you ease on the gas from a stop.
How else have you drove during those 78 miles? High speed runs for periods of time will cause pretty excessive heat build up. Potentially burning your belt up. The jumping feeling could occur when your belt begins to get small burs on the edge normally caused from excessive heat. Also running in high gear all the time is not good for belt wear. If your going to be under 15-20 mph definitely keep it in low. Above 20 then high gear. More technical side of it but rare is your clutches may be slightly out of alignment. While it’s not likely that’s your problem it does happen.
How long is too long in high gear?
Discussion Starter #10
I tried it this morning after it cooled down and it is working normal. It has always had a slight jerk when slowly accelerating. Is that just the nature of the transmission?
I would say at 40mph or faster for 10 straight minutes will cause a lot of heat build up. You need to factor in wether you have a load in the bed as well as running slightly up hill. All of that can factor into heat build up.
1 - 11 of 11 Posts
About this Discussion
5 Participants
Jmarco89
Kawasaki ATV Forum
Full Forum Listing
