Hi all, I was wondering what you all used for pulling the Rotor on the BF 650? Do you make your own puller? If so, how? Or is it just easier to buy the part from Kawie dealer? Thanks in advance for your replies. Andre
The Kawie puller makes it a lot nicer to pull the flywheel. I have popped them off with a little prying under the flywheel and tap the crank with a rubber mallet. Just be sure not to mess anything up. The Kawie puller is the safest and easiest way.
