1 - 10 of 10 Posts
I have an 06 KFX 400 all stock. When warming up it idles high with choke on about 8 inches of the pipe glows cherry red. When i took choke off and it idled down it went away but when i started to rev it up it would start to glow again. Is this normal or do i need to adjust something. Thanks
Sounds Rich.
I have seen other kfx 400 bikes do the same thing new and stock.
mine is is an 04 kfx and it does the same thing (has ever since i bought it) i ride the piss out of it and havent had any problems
Banned
Normally a glowing pipe means Lean. My 400 runs cool but I have not watched to see if the pipe glows.
mine also runs cool but when its pitch dark you can tell its glowing and so does my buddys 07 400 ex.
Banned
Like I said it is possible. I have not rode mine enough to notice much yet. I will keep a look out for it though. Got alot of work ahead to make mine the way I want it.
+2 on the lean situation if your pipe is glowing ... Something to do with your pilot system at start up or maybe your float is sticking momentarily reducing the gas flow !
My 04 KFX never did that but i just installed a CDI rev box in it and it will be running hotter for sure with the timing advance...
I had to move up from a 22.5 to a 25 Pilot jet on my son's 04 Raptor after i installed a CDI box on his machine.First time i started it the head pipe turned cherry red !
Cheers !
Phil
I got a 05 kfx 400 with a 145 main jet and HMF slip on pipe and a k&n and mine glows. Do you think i'm ok or do you think i need to change my pilot jet? my spark plug looked good last time i check it.
1 - 10 of 10 Posts
