Kfx
Dual exhaust
aftermarket air cleaner
drill jets 5/64
42 pilots
6 degree key
clutch spring
Crossover intake
Elevation in-between 700 and 800
Ok guys my Kfx isn't running right. It burbles in the right pipe on bike. It had 2 shims under needle but I took them out idk if that will fix it or not. let me know what you guys think about the situation and what I should do to fix the problem
To be 100% honest with you Dalton I forget what would be ideal for a stock motor with crossovers, I'm running 1/8 drill bit Jets in my stock carbs with crossovers for my high compression 715 with super Pros what I do know though is when I had stock internals with the Crossovers and the Muzzy super pro I was running 185's and it was an animal and I'm right about the same elevation in northeastern Pennsylvania
