1 - 1 of 1 Posts
Have an old KLF300 fking thing is dead. Was running fine earlier this year but not started for 4months. Its like the kill switch is off. Ive forgotten which is kill which isn't now, I tested anyway and continuity is good pushed to right as is the start button when pressed. Also power to brown wire is there to kill switch ok.
No solenoid click and no voltage registered at solenoid when i press start button although continuity at switch is good.
Jump lead from + term to start turns over good but no sign of starting plug is cleaned and gapped.
Can someone help here or supply wiring diag many thanks.
1 - 1 of 1 Posts
