You will be safe going with 28's and no lift but a 28x11x14 will not fit your stock rims, you would need a 14"rim. I think you will probably wanna go with a 26" tire or maybe even 27. The taller the tire the worse it is going to handle.
GOT2BRUTE what's up with the different traction in the front ?
you have diff models and they don't seem to be the same size or is it the taller knobby that gives it a bigger stance
The left looks bigger to me and the left looks to have different lugsGOT2BRUTE what's up with the different traction in the front ?
THey are both 28" but the fronts are 8" wide and the rears are 12" wide
Sorry should have mentioned that i did a lazyman's before and after, the tires on the other side are the 25" zilla's that i was running before the mudzilla's.The left looks bigger to me and the left looks to have different lugsGOT2BRUTE what's up with the different traction in the front ?
THey are both 28" but the fronts are 8" wide and the rears are 12" wide![]()
