recently replaced the thermostat on my 2003 prairie 700 once it heats up it starts flowing coolant from an open hose that looks like its coming from the coolant reservoir which in turn causes it to over heat. Not sure why this is, maybe air in the system? any ideas?
Here's the coolant flow diagram.
75410
What's causing the overheating?
Could be:
Plugged up rad
Blown head gasket
Bad fan temp switch/fuse
Broken fan
Air bubble in system
Bad thermostat
Bad cap
Low coolant
