06, 650 SRA.
There is a leak in the fuel tap. The gas seems to be coming from the three metal plates sandwiched together with screws on all 4 corners. It doesn't leak the same each time, sometimes just a little, sometimes alot.
Question is, I can find no part numbers or diagram of this peice dissasembled. I'm sure there are gaskets, O rings and such, and most likely that is the culprit. So, is this peice servicable, or do I need to replace the tap?
Thanks
Bump..... Anyone?
