I have a 2007 brute force 750 with 28" Gorilla Silverbacks. If i were two put a 2" lift on it with 2" spacers on each wheel would this be harder on the axles. The previous owner already went through a back axle and i'm just wondering if this would be a bad idea? or do you think it would be fine?
That is going to be harder on pretty much every suspension component as well as the axles due to the increased CV angles.
I have an 09 750 with a 2" lift, 30 silverbacks, been riding thru heavy mud holes quite a few times and haven't broken anything yet. (had the bike little over a year now) I watch how I use my thumb tho. Can't tell you it won't break but so far so good.
And dont use your locker
running a close to what you are describing ,with no problems in 6yrs
Throttle control is key, I just replaced rear axles from the stock 2006 axles and I have a custom 3'' lift and springs, with 30'' silverbacks with motor and clutch work. I am not easy on my bike. The spacers though you will be eating wheel bearings.
