I have a 2007 Kawasaki Prairie 360 4X4 that I can not get out of limp mode.
So far this is what I have tried:
1. Bought/replaced CDI box.
2. Bought/replaced speed sensor.
3. Even thought this doesn’t pertain to the limp mode issue,
4. I did replace the 4x4 actuator since it had went out on me on my last trip.
5. I also had to replace the 4x4 rocker switch.
~ All the fuses check out fine.
~ Battery is fully charged.
~ All the wiring is good as far as I can see.
~ The belt cover switch is on the right position.
~ It goes into gear fine.
~ I reset the check belt light, multiple times and it still flashes and stays in limp mode still.
( the reset method I used was from the Youtube videos I found)
I am at a complete loss and don’t know what else to do. I feel like Im missing something simple.
I would appreciate any and all advice or suggestions. Maybe another process to get it out of limp mode? Is there
another area I need to focus on? Look deeper into wiring issues? Pinched wires? Bad replacement parts? I have tried everything I know to try.
I am desperate! HELP!
