1 - 1 of 1 Posts
Can't get your belt light to reset?
Common failure points are your KEBC actuator, belt switch, 4wd control box and so on. Get rid of the headache with our KEBC delete kit!
Our KEBC delete kit allows you to remove your Kawasaki Engine Break Control, reset and bypass the belt switch! You have the choice of either leaving the KEBC actuator on your vehicle or taking it off completely. Your engine will perform normally and you will no longer go into limp mode again! Yes you read that right, you will never go into limp mode again!!
Hunting season is here, you don't want the nightmare of the 5mph speed limiter when you're miles deep! Get ahead of the problem;)
Brute Force - Prairie Kebc Delete + Hole Cover Combo
1 - 1 of 1 Posts
