Hello all!
I've been reading kawieriders for the last few weeks, as I am now the proud owner of a 2004 KFX 700!
I got this monster on the cheap from a guy who didn't ride it as much as he had planned (quads are streetable here in SD).
So, here I am:
I trailered the quad right from this guy's front yard, where it had (obviously) been perched for the better part of two years. I was told that there was a knock in the engine, and he didn't know much more than that.
I got it to the shop, checked the oil (at the dipstick), and it was a very light brown, and smelled of both gas and antifreeze. (I read in one post that its not uncommon for a carbed motor to leak gas past the rings if there's gas in the carbs, after a period of time.)
Well, today I changed the oil and replaced the filter, replaced the gasket for the downtube to the top of the motor from the radiator, and fired her up! And yes, there is a knock. The quad has an aftermarket exhaust (and rev box), and the knock is just about as loud as it! also of note: after getting her started, I couldn't keep her started: if I wasn't fingering the throttle, she would rough idle, then die. I expected this, since its been awhile since its been started, but after about the fifth time, I called it quits.
So, to help with the diagnosis:
I had to use jumper cables from my car to the quad's battery to start it.
I added a rough approximation of Stabil to the fuel before attempting to start it.
I checked all connections, fuses, and hoses.
I changed the oil with 2 quarts of Valvoline ATV 10w40 oil.
I had to manipulate the choke trigger while holding down the "start" button and throttle in order to get it to start.
After getting it started, I had to keep on the throttle (even if only a little) to keep it running.
There was a loud, timed knocking that seemed to be coming from the top, towards the front-most cylinder (had the plastic off that covers the airbox).
The knocking didn't get any more loud under throttle, just faster.
Also of note: the oil that was drained of the motor wasnt consistent in viscosity or color: the oil at the dipstick was more of a creamed tea color, and thin; whereas the the oil at the filter was sludgy, and a darker, chocolate milk, color. Furthermore, the knocking seemed to have one point of orgin, as opposed to multiple, synchronized, knocks.
I am mechanically inclined, but this is the most advanced machine that I've worked on that hasn't been a full-fledged automobile.
Any and all suggestions will be helpful, and I can describe any leading questions that you can come up with!
Please, kawieriders, you're my only hope!
Thanks in advance, and apologies for the lengthy post!
So, here I am:
