So Ill try to make this short and sweet. I have replaced the coil bought a couple cdi's. Checked for continuity. I CANNOT get this stubborn thing to even spark. Any last ideas before I take it to a shop? If Im correct the ignition circut should be able to run by itself independant of the other two. So long as you have the key to open up the circuts from ground. Confused and tired, any help would be appreciated.
