I'm not quite sure what the problem is, but when I start my Mojave, (doesn't have any trouble starting) I put the choke on full and it runs just fine, slight exhaust popping when it is still warming up. Then when I take the choke off it idles at a normal speed and then slowly dies down and shuts off, but starts right back up. I have to keep pumping the throttle when it's not moving to keep it alive. If I start it without choke, I just have to keep pumping the throttle. It runs just fine once you start moving and when you get off the gas while in gear until you start rolling to a stop. I tried adjusting the idle, and I don't believe it is that. I've adjusted the intake valves about 3 times in the past 4ish months.
Could they need to be adjusted again??
