I have an 87 mojave. Wouldn't run unless choked. Cleaned the carb with no help so I took it to a local ATV mechanic. he cleaned the carb again and said that he thinks it's either a timing or ignition problem. it will start, but as soon as you touch the throttle, it bogs and stalls. Even if you spray eather into the carb, it doesn't rev. Any suggestions?
2002 Mojave 250
Are you sure the jets in carb are in the correct place? The main jet should be 135 ish, I had the 55 air jet swapped and it did that.
