So I should have posted this earlier but this winter I got the mojave out to play in the snow and so me and my brother could pull each other on sleds. It hasn't been starting good at all for a while, in fact it has to be pull started because it just will not kick start.
But after we got it started it was running fine. I did run it through a lot of snow that was probably too deep but all it did was melt the snow off of the skid plates. After we sledded some my little brother got tired so I decided to have a little fun before retiring it back to the shed. I took off down the road for about a mile or two, or that was the plan.
I went all the way up through the gears and then I kept having this issue that after I got to the top of a gear I would loose power, and kept having the same issue until I shifted down into second gear. I determined that 1st and 2nd gears work fine, but any of he higher gears will not keep power. I really hope I didn't do something major like messing up something important.
After discussing it my dad thinks it might be the fuel filter is too plugged up and is restricting he flow once I open it up. No sure if that is the case or not.
Any ideas what it could be?
Any typos are purely the result of using a touchscreen to type this entire message, it tends to place random periods in random spots too.
