I noticed when I give my handlebars a slight push or pull, they kind of click and move, VERY slightly. I noticed it was the shaft that is connected to my bars (I would assume you would call it the steering column) This started happening like a week ago and haven't rode since. Should I be concerned? My buddy said there is nothing you can do about it. I ride about once every other weekend at a motocross track with decent sized gaps.
a little up and down (1/16th") is fine, but if its more then that you need to replace the pivot joint where the stem meets the frame (bottom).
no problem, watch it to make sure it doesnt get worse... You can always stick a washer in there and that's a good durable quick fix.
