I am trying to repair a Mule 600 for the Chaplains. It won't shut off! I figure that is a sign of a bad ignition and I ordered a new one to install this weekend. What else would you suggest to look at if this doesn't fix the problem? Also, how do I get the Mule to turn off, if this doesn't work?
Bonus question: When poking around, I noticed this wire (circled) coming off of the battery. Any idea what it is for?
Motor vehicle Automotive tire Hood Tire Tread
Kawasaki Mule 550, KAF-300-C5
That red wire looks like someone else added it
The kill on these mules are igntion coil grounding.
There is a kill wire that plugs onto the coil, and on some mule's it then plugs into a longer section of a wire, so there are 2 places where it can come unplugged.
best thing to do is locate a electrical diagram and trace the wire.
Solved the problem. When I took the dash and wheel well cover off, I discovered that the ignition switch wires had been snacked on by a critter. Rewired the broken wires, and it works again.
Thanks
