This past Friday my engine started missing, and the first thing I checked was the plug wires. The spark plugs are accessible under the black plate on top of the engine. I pulled the first plug wire off that is next to the oil fill plug, and there was no change in engine sound. I plugged it back in, and removed the next plug wire and the missing got worse. Plugged it back in, and removed the final one. Same deal, missing was worse. So I figured I either had a bad plug, bad plug wire, bad coil, or dead cylinder! I decided to do the easiest check possible, and switch plug wires to rule out the wire. I completely swapped 2 wires, and luckily the miss followed the wire!
This is on a 2017, so I called the dealership to check if this was a warranty item. They confirmed it was, but the cost of a set of plug wires was cheaper than what it would take for me to make 4 trips to the dealer. So I just bought them!
After replacing the plug wires, my mule runs perfect again! I asked the parts guy if this was common problem, and he said that he has sold over 50 sets of plug wires since he had been working there (less than 2 years). Seems like allot to me.
