I've got a 2020 FXT Ranch edition I was interested in changing the front tires to be same size as rears. Can this be done without other modifications to Mule? Can I either find some "take off's" from another Mule with same rim style and fit the bigger tires up front? Or if I buy just tires same size as rear will they fit the front rims as well or are front rims different size?
Thanks
The front wheels are 7" wide, the rear 8" wide. I would not put the rear size tires on the front wheels. I do not know if there will be clearance issues using an 8'' wheel and rear size tire on the front
, but since you have them (on the rear) you could try mounting them on the front and check for clearance issues, turning left to right (lock to lock). Also suspension (compression) may cause clearance issues too
Your front tires are 26-9.00 x 12" and your rear are 26-11.00 x 12"
