Hey y’all! We have a 2021 Mule Pro-FXT it won’t turn over-gives code 31 (Vehicle down sensor) so we ordered a new one and still nothing.. I have gone through all the wiring I can see, checked fuses and grounds, nothing out of the ordinary. Fuel pump doesn’t turn on and if you jump the starter to crank it won’t give any spark either.
Called the dealer they are 8 weeks out “on the generous side” and would like to have the machine back for thanksgiving.
Anyone have a wiring diagram for what wires go into the ecm from the vehicle down sensor to check continuity, or other input to go from here?
Thank you!
Discussion Starter · #2 ·
Putting this out there for anyone else having a similar problem…
Decided to start pulling panels today. Found the main wiring harness behind the front electrical panel was chewed by a mouse. Solder the 3 wires chewed and it started right up.
