Hello all, brand new to this forum and just picked up 2021 used Mule SX Camo HC FI (KAF400S). So far so good, started at -18C (0F), drove thru foot of snow in yard with unlocked rear diff and 4x4, no issues.
In reading specs in owners manual pg 16 it indicates different “transmission” gear ratios on the models that have the XC 12” rim and 26” tires. It also lists “overall“ drive ratios so anyone know if Kawasaki actually revised some gears to accommodate the larger tires. I checked some part look ups on the R/S/T models vs KAF400P base model with 10” rims and 24 tires but couldn’t find where the gear ratio difference was. I was considering a taller tire upgrade 27/28 to gain more clearance but now questioning whether that’s a viable option. At 0F driving down lightly snow covered road other day it seems like low range was close to same top speed, just higher rpm. I was in 4wd and nothing seemed odd just no more pedal room on hi range lol. Thinking it was pushing the 13 hp limit and didn’t have any umph left to get it up to the 25 mph speed, motor wasn’t lugging just less rpm. I’m sure if I aired up tires to spec and warmer out it would be fine. No matter I’m happy thus far as I didn’t buy it for speed, bought a 60” plow that links to rear hitch so fingers crossed it has enough power to push that around, haven’t installed it just yet.
Cheerios
Cheerios
