1 - 12 of 12 Posts
Muzzy Vforce exhaust for sale. It has an oval canister. I dont know if it's a pro or super pro.
I picked it up hoping it would fit my Prairie 700 with a little work. It's going to need more than a little work to fit.
There is a scrape on the bottom of the can a few dings on the piping. It looks like it will need a repack and a couple clamps before being installed.
$300 shipped or trade for a Muzzy that fits my Prairie 700.
man this summer
i cut up a prairie muzzy so i could have muzzy duals on my kfx700/730
i can see what pipes i did not use if you want me too
I'd love to see what you didn't use. The vforce front cylinder pipe looked shorter than the prairie and hit the frame by the 180 degree bend. The rear cylinder piping would require relocating the coolant overflow reservoir, not a huge issue, and also hit the frame.
remembered wrong.
we use the front part of the front pipe.
still have the back half of it.
you could weld the front of what you have to make it longer.
we have the rear pipe and the part that circles up.
you then might be able to make it work with the cross over.
but i think you would need to extend the length before the muffler
Discussion Starter · #7 ·
Thanks for the pictures! The pipe diameters on the prairie pipe look like they are a smaller diameter or taper compared to the kfx piping possibly.
Does the y pipe where the headers merge look similar?
Would you be looking to part with these leftover pipe pieces? I'm willing to give it shot and see if I can piece something together.
the y pipe seems shorter for the kfx , you may have to extend it.
if you measure your pipe id's and od's i can measure mine also and compare.
yes i would willing to part with these.
also if you cannot make it work i would be interested in the muffler from you.
1 - 12 of 12 Posts
