It is time to change the belt and I have a few mod questions.
I ride mainly trails and hit the sand dunes up a couple times a year.
05 BF 650 SRA INFO:
1. 25" Mudlits XL's on stock rims.
2. DYNATEK CDI
3. FULL HMF
4. K&N Air filter
Questions:
1.) Should I upgrade to an EPI maroon primary?
2.) Do I have to upgrade my secondary spring if upgrading my primary?
3.) If I do up-grade my secondary spring what should I get?
3.) Do I keep my stock setup and replace my belt?
4.) Should I buy an OEM belt?
Thanks for the Help!!!
1.I don't think it helps the 650???
2.no
3.with 25" tires leave stock
3.:confused: your setup is fine might want to go with stage 3 clutch for more top end
4.always the other brands will not hold up as well
1. i have the maroon. it does good. get in touch with vforce john. he has some new springs he designed.
2. no.
3. leave stock. i run 28" zillas with a stock secondary
3. refer to #1 call john at 570-773-1721 he will get you straight.
4. yes pay the extra and get an OEM. nothing out there compares
good luck
EPI Reply
I called EPI today and they recommend a pink primary and black secondary? Does this sound right? i want to stay as close as stock as possible. If my bike lifts the front end anymore I will have to pull of the throttle when drag racing. Let me know what you guys think?
i have an 08 sra. just got my clutch back from vfj. i installed the maroon primary, it helped a little. it does have a little more stall than the stock spring. you dont need to change your secondary spring the stock is fine. i did the stage 3 with the spridermod and the kebc removal. its awesome!!! more power from bottom to top. i agree with the others, only buy the stock belt.
