1 - 1 of 1 Posts
I'm working on a 1996 (I think) Bayou 400, and it used to run fine, now it won't start. One of three things happens: no dash lights come on and it doesn't start, you can fiddle with the ignition switch and key and green neutral dash light comes on and it wont start, or you can fiddle with it and it'll start and the green light comes on, and then itll turn off a little bit later. I just took apart, cleaned, and put dielectric grease on the contacts of both the ignition switch and key switch, and the neutral light wont come on. The headlights came on when I turned on the key switch before I took them out to replace earlier today.
If anyone can make a suggestion or find me a wiring diagram for this thing it would be much appreciated, thanks. In the meantime, I'll keep tracing wires, etc.
-Jason
1 - 1 of 1 Posts
