So I bought a bayou 300 4x4 a few months ago in the hopes of getting it running, I managed to get it running but when I shift from reverse to 1st it dies and won't start again. Any ideas as to what would cause this?
One thought is that the reverse switch is providing a system ground and when you open the switch, that ground goes away stopping..everything. Check that your chassis ground wire...not the negative battery cable, is connected to the engine block.
