1 - 9 of 9 Posts
i am looking to do some low buck mods to my prairie 700 this is what i have done so far 12hole mod, jet kit, shims under needle, ring cut on springs HMF exhaust, UNI air filter what else can i do to gain more power i mainly do trail riding and mud bogging
Install a holeshot module from Diamond G racing or moose.Thay are alot cheaper than buying a complete ignition module .Then play with the springs in the clutches.If you are intimidated buy picking the right ones you can just get a clutch kit.
IMO, spend the extra $75 bux and get a Dyna ignition. If you just get a module you will be wanting more in short order.
The best mod you are missing is the the primary clutch top speed mod. You will gain at least 5 mph top speed, plus that dreaded "dead spot" that you hit at about 50 mph will be moved at least 5 mph higher, thus giving you faster acceleration in the midrange.
I agree with Nova. Get a Dyna (non-programmable) CDI and the primary clutch mod (VFJ or Jim can hook you up with this clutch work). Those 2 mods were the best bang for the buck that I ever did (before I got a bbk).
They are correct. Dyna cdi is the way to go, much better gain than a module. Clutch primary spring and machined clutch will put a smile on your face. I also noticed a very big gain in the butt dyno with the cross over intakes from VFJ.
I have a cheap suspension mod for you in the for sale section with pictures. Progressive adjustable spring kit brand new $100 shipped.
Discussion Starter · #6 ·
thanks for the info guys i will try the clutch mod & dyna cdi and let you guy know in a few weeks on the results thanks a lot
Discussion Starter · #7 ·
as for the clutch do i need to buy a clutch kit or just the springs how do i find out more about VFJ
Look in the "Interstate Motorsports" section on this forum.
You can also go to VFJ's website. www.vforcejohn.com His ph. number is listed on his website too.
1 - 9 of 9 Posts
