So last night I was bolting the front head on and something strange happened. As I was getting the head bolts started, I noticed some coolant in the top of the head that I thought had just dripped from the coolant hose when I wasn't looking. I soaked it up and continued tightening the head bolts down. Got all done assembling the whole cylinder and just happened to notice some drops of coolant hanging on the bottom of the head right where the gasket is. At first, I thought that it had just run down the side of the engine from the coolant hose, but I could not find a wet spot above the gasket anywhere. Those drips had to come from the gasket itself. So now I am thinking that there must've been some residual coolant from the disassembly process that was in the thread area of bolt hole #1 (the front lowest head bolt hole without a dowel pin) that must've pushed up the bolt hole when I put the bolt in there, and it ran out the bottom along the gasket as I was tightening the head bolts. And another strange thing is that the coolant that came up past the bolt was clear and perfect green. You'd think that if it pushed up past the bolt that had black moly oil on the threads and under the washer would have been nasty looking coolant, but neither the drips at the bottom of the head nor the bit in the top of the head were black at all.
So anyway, now I'm not sure what to do. Should I take the head back off and see how much of the gasket is wet, and see if there's more coolant at the bottom the head bolts? Or just go run it and see if the head gasket leaks?
