Have a kawasaki lakota 300. Chain keeps coming off, so replaced with new. Chain kept coming loose/off so I would tighten. Well now the back left tire chain side is being pulled in at an angle. Why?
Chains come off for several reasons...warn sprockets, warped chain, alignment problems..yours sounds like an aligngnment issue due to a possible axle bearing issue. Pull the chain, jack the rear off the ground, move that tire and axle and look for play or movement in the bearing case. Probably time for a rebuild.
