1 - 8 of 8 Posts
Might want to check the ball joints at each end of the tierods for starters.
at the end directly under where they connect to the steering stem ?
Yes there and like on the hub/spindle area. Make sure one of the nuts didn't come loose and the cotter pin didn't come out..
i have a 05 brute with aftermarket tie rod they get loose sometimes .i take off the cotter pin i put a wrench under by the ball and wrench on top under cotterpin just tighten them up i dont know if yours are the same
Discussion Starter #6
i try to tighten it and all it does is spin...what do you think i should do ?
on mine i can put a wrench on top nut and a open end wrench underneath to hold it from spinning take a close look to see what i mean but i have aftermarket tie rods they might be differient
Discussion Starter #8
yup
yea thats what my buddy told me to do. kinda obvious, shouldov just done that from the start. im gunna go try that. thanks for all the help everyone
1 - 8 of 8 Posts
